I had problems with this last summer, but now its starting to act up again now that its getting hot out. My problem is at low speeds, specifically idle. With my AC on, idling in traffic on 105+ degree weather (in the sun, at night when its 100+ i don't seem to have issues), my temp seems to climb. I have an aftermarket gauge so i can monitor temperatures more precisely.
Sitting idle after exiting the freeway is when the problem seems to get the worst, temp slowly climbs from ~180 up to 210+. Here is everything about the car in list form.
Non turbo, stock
Fan shroud in place
Brand new fan clutch from Toyota
10 blade Turbo fan
Brand new Radiator
New head gasket last summer (NO signs of BHG at all.)
All heat shields, under engine covers shrouds everything in place
All fins on condenser AND radiator are strait and unobstructed.
Toyota Red coolant, 50/50
New OEM Toyota Thermostat
New upper hose+Toyota clamps
Cooling system recently flushed
No leaks
New belts
All hood seals in place, hood heat shielding fiberglass stuff in place
No coolant loss
When i take off from the stop i can hear the fan roaring, which tells me it is in fact engaging properly, and soon cools off. Also, if i sit there idling and heating up, if i pop the hood open all the way, the temp quickly drops to normal.
Any ideas would be great.
Non turbo, stock
Fan shroud in place
10 blade Turbo fan
Brand new Radiator
No leaks
New belts
No coolant loss
