Overclocking - Are you one of the loonies...
TheHeffNerr said:
o_O water cooling is sooo much better then air cooling, i personally use air cooling because it's much more of a challenge to keep the temps low and a high overclock, imo water cooling is cheating.
google, use it, learn something.
My friend that has more money, builds computers for a living, and upgrades every couple months has had both...
A well designed case with good airflow (not tons of fans, you need directional FLOW) with good heatsinks will be just as effective as water cooling (unless you cheat and use ice in the water or stick the radiator outside).
water cooling is NOT durable enough for quite a few reasons, but I'm not arguing about this...
flight doc89
Registered Murse
Apr 21, 2006
227
Bessemer, Alabama, United States
I have been too lazy/too poor to do anything to my comp. Athlon 3800, DFI Lanparty SLI-DR, 1Gb Kingston :cries: 2x 7600GS in SLI, all running pretty much stock.
Once I get some spare cash, ima get some better/more ram and better cooling then i'll be set to step it up a little :D right now i've just got a couple case fans and a PCI-slot fan under each vidcard. I wanna big typhoon and better heatsinks for the vidcards before i overclock it.
What are everybodies 3DMark scores? single card, i got 3500, SLI got 6500, rivatuner overclock pushed like 6700-6800 (3DMark05)
EDIT: me want
Pardon?
5 years here without a single issue.
TheHeffNerr
(?'-')? Q('-'Q)
Edmonds WA
www.theheffnerr.com
ok, drain your coolent out of your car, stick some fans on it, and see how long it will last....
Fuzz420
Are U Here 2 take My Baby
Ive been on a High Definition binge lately. Been download movies in 720p. Im glad i can finally play them. Only down side is the movies destroy my rapidshare account.HD movies are demanding on the system, im glad ive overclocked they damn near play flawlessly unless im running other programs
tissimo
Stock is boring :(
Melbourne, FL
my e-penis has grown larger
Lol. it restarted in prime after about 10-12 minutes (w/ 2 sticks). I thought it was the 4 sticks of memory soo took 2 sticks out and tested. Before only lasted 4-5 minutes (w/ 4 sticks) so got more but still restart... oh well... temps hovered right around 68-69.. I had the vcore set to 1.50 in the bios, but vdroop down to 1.43v in load.
It ran 3dmark06 again though..
14980, lol
http://service.futuremark.com/compare?3dm06=4494792
The storey behind this.. Its a bone chilling 32-33*f outside (COLD!!! for FL) and my rooms probably a good 60 or so so decided to play around.. hahah
let see if i get 3.9 or 4.0 into windows for a cpu-z shot, hahahah! and maybe crack 15k in 3dmark
tissimo
Stock is boring :(
Melbourne, FL
yea I opend the window in the room to try to get the temps down more for the 3.9, but didn't go.. maybe with more voltage.. but was too chicken..
