As I was going up a hill it made a horrible noise almost like the turbo seazed up or somthing sounded like bearings locking up. I really don't know what happen but I know its not missing and the only way it will run is if I hold the gas down and even then it fights like crazy to go. It has no power in gear and and it has to be floored to even move. But then at full throttle I will get like 8+ pounds of boost and and will start to move once the motor catches up but with very little power. Maybe my wastegate is stuck or somthing I'm really scatching my head on this one, the only codes it shows is for a coolant sensor that the plug is broke on. Any help or suggestions would be helpful just for a starting point. Oh and its a stock turbo, stock boost usually runs at 6 psi. Thanks once again.
