Ok, I guess its my turn
2jzmk3
Guest
polobai said:
mr. GT4082 with a .82ar (thanks Sean for sourcing the backhousing for me). Had the lines made at a local shop here.
No problem
Ray it coming along nicley bro.. its going to very sick when its done. i wish mine was as clean!
polobai
Orlampa
close up of the injector wires. I feel like I extended about 600 wires, but it think it came out well.
polobai
Orlampa
extended TPS wiring, and IAT wiring for MAF pro. Word to the wise, be careful if your using an old or original harness-the wires are VERY brittle-be prepared to replace most ends.
2jzmk3
Guest
looks very good. nice a clean, its going one of the sickest engine bays once its completed. another excellent example of a mk3 done right! no shortcuts!
polobai
Orlampa
Thanks alot Sean, here are some updated pics from more mocking up this weeked. First is my compressor housing I had polised by Tony on supraforums (TT6spd95)-he does amazing work!
polobai
Orlampa
heres more-basic mock up of the intake manifold and pipes. i also created some panels to cover where the battery tray is, and clutch master cylinder.
polobai
Orlampa
close up of battery tray cover, you can see how the blow off valves will be mounted also.
polobai
Orlampa
Thanks, in my last setup I had one adjusted to handle low boost, and one for higher boost, same uses for this setup. Heres a pic of my alternator relocation setup.
2jzmk3
Guest
SupraJDS said:
Looks great man.... But what is the point of 2 Blow off valves?(not being a dick)
hks ssqbov are only good for about 28psi. anything more and the tend to start leaking, when you run two it makes them a little more reliable. and they sound awesome!
polobai
Orlampa
Thanks, I am definatly trying to make it to the meet-but I am not rushing anything. It really depends on how long the powercoating takes to complete. Thanks for all the comments guys!
