Oil through the bov ???
OneJoeZee
Retired Post Whore
aboard the Argama
SupraClaou;877002 said:
With the 7M I could low the boost as low as 3-4 psi!
I start thinking that the 7M wasn't so bad :icon_bigg
Then something was wrong with your 7M somewhere. Stock boost on a 7M is 6-7psi. If your's was only boosting 3-4 max at times, something was out of place not associated with the boost controller.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
SupraClaou;877113 said:
:icon_bigg
Stock hose route with a Greddy catchcan in between.
I didn't want to vent the pvc vacuum to the atmosphere...cause
I think there is a reason that the factory hose route is the way it is!
Hey... I also want to make a presentation of me and my car with
some photos.Should I make it in this section?Then you can check out
my catch can by eye
Sounds good to me, in that case it sounds like your turbos going (like others have already stated).
You can post pics in the subforum of the general section, the "gallery". Let's see those pics :)
