IHI-RHC7 said:I see, It's beautiful. Is there no room to mount the sender directly on the block?
Or just run braided to a remote mount?
Thanks
jetjock, the fitting is kind of a heinz 57 fitting. Theres a male-femal bsp-npt STEEL fitting going into the block. from there is a brass male-male fitting going into the 45 degree brass block. The oil sending unit is screwed into the 45 brass block. So are you saying that the only stress point is on the fitting going into the block? If so I should be ok as that one is steel.
edit: now that I think about it, there may be only two fittings, the steel male-femal bsp-npt fitting, and the 45 degree brass block (it may be female-male), so no male-male brass fitting in between. Hard to remember, as this was a couple years back that I did this.
