Hello Everyone,
I am in the process of building my 7MGTE and my machine shop hot tanked the block. I just replaced the freeze plugs and will be replacing the oil shaft bearings. My question is what can i use to shim the bearings? Once the bearings are pressed in the clearances are out of spec on these new bearings. Any help or suggestions is greatly appreciated. Thank you.
Ricky L
Ricky L
