oil pump drive gear wont fit!!!
p5150
ASE and FAA A&P Certified
Central Idaho
TooGoode;1072377 said:
what i ended up doing was atatching the shaft to a drill press and turning it on then going over the journals with 800 grit for a little while....it fits!!
Called it!
figgie
Twin Cities, Minnesot-ah
gaboonviper85;1072831 said:
I'm guessing the spec is around .0015" to .0028" for the bearing oil clearance on the oil pump driveshaft....don't quote me.
everyone skipped over my post! :p
figgie;1072490 said:
By chance
did you actually measure it per
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=EM&P=84
instead of guessing?
which Ian re-pointed out again :)
IJ.;1072839 said:
Steel backed babbit by the looks of it.
Don't "guess" if you're going to suggest tech fixes go look the actual spec up ;)
gaboonviper85
remember!
Close only counts in horseshoes and handgrenades. Machine it is either in spec or out-of spec.
gaboonviper85
3,236
Northeast Philly
gaboonviper85
remember!
i was compensating for outdated 20 year old oil tolerances...lol
and i was in fact "in spec" according to trsm....i was within the tolerance they give.....i was within .0005" on the tight side and .0002" on the loose side.....and a maximum clearance of .0031" id say that what i told him was correct info...no need to correct my badassness....lol
Goon: You're missing the point it doesn't matter how close you are don't "guess" .......
The specs are there if you don't know for sure look them up if you're too lazy to do this STFU and don't post.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,278
69
Atlanta
In any case, problem solved, proper advice(take it back out and mic' it) has been given.
We'll wait for the "7M shortblock wanted" post if he doesn't do it.
:biglaugh:
gaboonviper85
3,236
Northeast Philly
you took my mojo away :(
It won't happen again....*walks away kicking at the dirt*
