jdub said:That could be because your oil pump pick-up is too high in the pan
You might want to run a quart over full.
Also, read post #10 again...I thought I explained it pretty well.
But...what do I know :icon_conf
No you've been a huge help man. Would it make a diff that I changed over and used an oil pan from a GTE? I thought they were the same but maybe Im wrong? Ill add in 6qts today in a few mins when I change the oils. I usually do 5 but lets try 6! haha
