Hey guys, I need some advice on where to go with this and what to do next...
the 7MGE has been installed in my car for about 5000km and running great. One of my electric fans died and I stripped a bolt out of the water neck, so I had to work on the car to replace those things.
The car also has an oil leak (I rebuilt the motor myself) and from what I could see, it looked like the front main seal as you will see from the first pic...so I started taking everything apart.
and found this:
Interestingly, dry around the crank.
and behind the crank pulley was dry too.
little bit of dirt here, but no oil
dry in the timing belt area..hmmm this is kind of good and kind of bad news!
oily dirt here
From underneath. don't mind the red coolant and powersteering fluid. PS pump, waterneck and rad were replaced when this pic was taken.
again.
a few bolt holes on the oil pan are wet
the once spotless transmission is wet and dirty too
and yet, the back of the oil pan isn't nearly that oily...rear main??
so, it looks like that oil around the crank pulley on the front cover was creating an illusion that the front main was leaking. I'd imagine at highway speeds the fine mist of an oil leak somewhere gets spread around from the spinning belts in such a way that makes it look like the from main is leaking.
why so oily around the left side/ water pump area?
so...I ran a ratchet over every bolt on the pan and nearly all of the weeping bolts were loose...could this be the solution to my issue? why is the transmission so wet? I wonder of the rear main has been leaking...the clutch doesn't act like it's soaked in oil, would it even get oil on it?
I used "right stuff" gasket maker on every gasket that would normally be paper... brake cleaning before installation. the motor has a crank scraper, which mean liberal application of sealant. I used IJ's washer trick on the ends to prevent pan distortion. I wonder since so much sealant was used, the gasket may have shrunk a little bit as it cured, and I should have retightened the bolts.
The question is,
-where do you think it's leaking?
- anybody experienced anything like this?
- best way to repair?
- can a leaky oil pan gasket generate this much oil on the transmission?
my current plan of attack is to ensure oil pan tightness and the front plate. get the motor back together, clean everything up and use some UV dye in the engine oil and see if I can track down the leak. Thoughts, comments suggestions and experience welcome!
Steve
and found this:
oily dirt here
again.
The question is,
Steve
