oil in coolant
JASONA70
nomnomnom
Oct 27, 2006
743
socal
:cry: so im draining my 1JZ rad, and it looks like i have oil in my coolant. this in fact created an emotion of sadness, therefore i am sad. :cry::cry::cry::cry::cry::cry::cry::cry::cry::cry::cry::cry::cry::cry::cry::cry: im going to drain my oil tomorrow and then do a compression test. you guys know where im getting at.. hopefully it was just broken seals between the twin turbos that let oil seep through my cooling system. ill update this, rare case of bhg on a 1jz? possibility, if so.. then 2jz here i come.
pbasil1
Fully built 1JZ project
Jan 30, 2008
402
Huntsville,AL
I have a similar problem... Opposite though. I have coolant leaking into my oil. I have a leaking head gasket and im rebuilding my 1J. I will be using a 2jz block though, it just seems dumb not to...
Sorry to hear of the troubles!
JASONA70
nomnomnom
Oct 27, 2006
743
socal
oooooh gl on your 1.5jz ! hopefully i didnt catch the bhg disease. i had it on my 7m and i was sick and tired of it.
JASONA70
nomnomnom
Oct 27, 2006
743
socal
trydrew;915297 said:
You sure it's oil and not buildup?
i did a coolant flush 2 weeks back when i blew my twins again. I dont think a car can build up so much crap within 2 weeks. the coolant that i drained out looked really really really brown like shit mixed really well with water.
Frank Rizzo
478
Fixing your girl's car
Don't be so quick to condemn it. That would have to be ALOT of oil to contaminate all of the coolant. Sounds like classic cooling system corrosion/rusty water from having too low of a concentration of antifreeze probably most of its life. I've pulled BLACK (yes black) coolant out of many cars and rusty brown out of just about every other, without having a blown head gasket. And doing 1 or even 2 flushes is not going to remove all of it, in some extreme cases you will never remove it all no matter how much you flush.
To be 100% sure, just run a simple block test, it will help you sleep at night.
JASONA70
nomnomnom
Oct 27, 2006
743
socal
ya ill be doing a compression test later on the week. it makes me feel a bit better knowing it might not be another ::bhg:: thanks
Frank Rizzo
478
I said block test, not compression. You are better off leak down testing rather than compression testing if you are going to remove the spark plugs. I've had a BHG or 2 go undetected by just a compression test alone.
Compression test does not = 100% BHG detectability.
Block test = 100% BHG detectability!!
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
run a coolant system cleaner, prestone cleaner kit. you usually want to with JDM 1jzs because they might have been sittign there for a while, run it and it'll clean all of that crap out and you should be good to go. when i got my 2jz i took off the thermostat and all i saw was brown sludge (do a search on the forum you might find the post i think either doward or jdub responded to on how to remedy it)
i wouldnt worry too much unless i see it in the oil hehe
there is also a BHG test kit isnt there? i heard they work to some degree... or they fail horribly.....
Frank Rizzo
478
