Well it looks like I need to revive an old thread
. I had a few other questions regarding oil pressure vs flow.
Question 1:
I hear this tossed around so much on this forum "The 7M has a low pressure high volume oil system"... I just cant wrap my mind around what this means. The bearing clearances are not any bigger than any other typical engine which runs higher oil pressures- therefore the increased flow cannot be through the bearing clearances. The only other increase in flow compared to a different engine (that I can think of) would be the factory oil cooler (not even present on most non turbo's). Granted, the 7M does have more bearings in total compared to other engines, but each bearing will not flow more oil than that of a different motor, considering the clearances are about the same if not smaller in the 7M. Now considering the clearances are all pretty consistent with other engines, where does this "high flow" label for the 7M come from? From all I can gather, considering the restriction is constant between the 7M and other engines, and the pressure is lower than that of other engines, the flow through each bearing clearance would be less in a 7M than that of a similar engine....now I know there must be something flawed with how I am looking at this, what I need is someone to tell me where because I cant seem to figure it out!
Assuming restriction stays the same (small block chebby vs 7m, if anything 7M has tighter clearances), pressure/flow will increase and decrease proportionately, so how is it that the 7M restriction is the same/similar, the pressure is lower, but SOMEHOW flow is increased.
Question 2:
Am I right in saying that the bearings are the greatest point of restriction in the 7M oil system? Assuming this is the case, why would Toyota choose (on a high performance engine) to lower the pump volume and pressure? Assume with the stock oil clearances and 0w30 oil that maximum pressure on the bearings before erosion and other things affect the durability of the bearing, was about 70PSI. With clearances constant, and pressure at 70PSI, flow would be at its maximum. Any reduction in pressure at this point would directly correlate to a reduction in flow through the bearing clearance. In an ideal system, wouldn't running pressure be 70PSI at all times?
Because the engine speed varies, of course constant pump volume is not possible without some type of control. Why not create a pump that will allow for 70PSI (max flow) at idle, and as engine/pump speed increases, relieve any excess volume through the relief? This way, 70 PSI (and maximum flow) can be achieved regardless of RPM. Would this not have a positive impact on engine life and lubrication?
There are only three reasons I could think to NOT do this. One would be cost- maybe manufacturing this higher volume pump would be more expensive. Two would be gas mileage- maybe the extra load on the engine at all times would decrease gas mileage. Three would be space- maybe there is not enough room in the engine to fit a higher volume pump?
Anyone care to enlighten me here?
