oil drain plug leaking help?!!
chosupra
8
central california
So I did an oil change on my soop today. After I replaced and retorqued the drain plug I noticed oil dripping from the drain hole. I bought a new gasket for the plug and it was still dripping. So I've been reading older threads and looks like I may have a drain plug sealing surface dent (probably guys at Walmart auto service over-torqued it and fucked it up). I kinda have an idea of how to fix this but Im gonna have to take the drain plug off and I was wondering If I can just drain and re-use all that oil cuz I paid a shitload for all that oil and I don't wanna waste it what you guys think? any suggestions on how to fix that leaking problem?
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
If you do decide to re-use your oil, make sure you have a good container that you can put it into. You do not want any contaminants in it. I have used a little Teflon tape on the thread, and a new gasket for the plug and it stopped my leak. Maybe you can try this.
chosupra
8
central california
so I found out some threads around the drain hole were cracked so I bought teflon tape and gasket maker. Wrapped teflon tape on drain plug and sealed the gasket on with gasket maker and I even used gasket maker around the drain plug after I torqued it. Now its on tight no leaks! hope it won't be a pita takin that plug off next time
