Parts are on there way in and pics to follow by the weekend (assuming they come in on time).
$43.30 = 2nd gen rx-7 oil cooler (built in thermo, and MASSIVE) LOST 5-8 PSI through the rpm band. Psi still within specs though.
$4.21x 15ft aeroquip socketless hose (hell of a work out)
$12.84 = Push lock hose ends 1/2-1/2, ($2.14 X 6)
$23.10 = Metric to NPT fitting M18x1.5-1/2 pipe thread ($11.55 X 2) HARD TO FIND
$23.88 = Perma cool remote filter mount 1/2 fittings 3/4-16 filter threads
$19.95 = perma cool spin on filter adapter 1/2, 3/4 -16
$9.75 = summit S&H
$10.04 = DiscountHydraulicHose.com S&H
TECH NOTE: per mazda shop manual, IN to cooler is the fitting facing up. OUT is the fitting facing 90 Degrees and on the same end of the end tank with thermo stat .
$9.75 = summit S&H
