Anyone have a list of the parts I need to remove the 7mgte oil cooler? I've read that it really doesn't do much and becomes a disadvantage towatds oil pressure. I know I need to remove the old oil filter housing and oil cooler as well as find a bolt to plug the oil cooler side but what about the part where the oil filter goes? Will I just be able to install an oil filter once the oil cooler adapter is off or do I need some sort of adapter?
Thank you!
Thank you!
