oem valve spring compressor
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
The snap-on one is like $40 IIRC, I am good enough at using it now that I use it when heads are off too. It can be tricky until you get the feel for it.
bfr1992t
The quiet one
Oct 29, 2005
272
Ohio
That's not what I'm talking about. Mine has two brackets that bolt in place of the cam bearing caps, a long rod, and a lever/handle assembly that fits over the retainer and in to the shim bore. It's $175 IIRC.
MA70witBoost
Registered Drifter
