IJ.;1547127 said:Yes, if you have a pulse and the injector is clean but the engine note doesn't change when you unplug that injector I have NFI what's going on....
Put it back together swap some injectors around and see if the problems follow the injector or the wiring..
well I got it back together and did what you said. I have pulse when its running and when i unplug it the engine note doesn't change. I swapped the injectors around again and it seems to follow the wiring and not the injectors. But only cyl. 1. I also have NFI whats going on.
---------- Post added at 02:31 AM ---------- Previous post was at 02:29 AM ----------
Another thing I know for a fact that it isn't the wiring harness because it did it on my 87 harness before I switched to a 91. And all I did to fix the problem that time was change the spark plugs.... So I think there is something seriously wrong with the motor.
Would an exhaust leak cause this happen?
