Idealsupra said:i find it VERY hard to believe there is NO port on the turbos compressor housing for a vacuum line. and frankly if there isnt i wouldnt be using the turbo because its a POS. lol
MK3Brent said:A lot of turbo's don't come pre tapped anymore.
boostadikt said:if so you probably bought one of those revamped diesel turbos with an exhaust a/r of 1.15
LordLo said:As for the wastegate I didn't place the curved adaptor plate on, which may help the valve on the wastegate seal. I just placed the wastegate directly onto the pipe with no adapter plate so that's probably what's causing it to leak since I can hear the turbo spooling around 2,000 rpm it just doesn't build boost.
theWeezL said::nono:
ummm...
yeah, :nono:
edit: << see my avatar.
LordLo said:Luckily, my stupidity saved my engine. :biglaugh: Hopefully, this adaptor plate helps.
tErbo b00st said:This board just moves way too fast for me :aigo:
