ok replaced cps know its good coil packs all test out good. think the igniter is ok. whats next any info would be a huge help.
JStoked;1592759 said:ok replaced cps know its good coil packs all test out good. think the igniter is ok. whats next any info would be a huge help.
Van;1602168 said:So, what happened here? I have a no spark problem too. What did you do to get your Supra to start? Thanks. Van :1zhelp:
Van;1602168 said:I'm about to go step-by-step through the troubleshooting process set out in the TSRM, plus what JJ stated in an earlier post.
To the OP: I have a no spark problem too. What did you do to get your Supra to start?
The IGN 7.5 amp fuse was intact. I tried to restart, but no go. It's time to take it to a mechanic...:3d_frown:Tomorrow I'll see if the IGN fuse is still OK.
Nick M;1603530 said:You aren't doing anything like pumping the gas pedal while you try and start are you?
I purchased a brand new, engine wire harness, new injectors, new main EFI relay, new fuel pressure relay, and checked all the other relays too, but didn't even think of checking their connections for power. :nono:metaphysico;1603500 said:That may be the best bet unless you know your way around wiring diagrams and electrical testing. You may have ended up blowing a fuseable link somewhere or a wire itself and they can be hard to track in an entire harness.
But when checking fuses, make sure that not only should u check to see if the fuse is ok but make sure its getting power too. Had a power wire come off a friends started and hit the block, it fried a bunch of fuseable links behind the fuse panel.
Thanks for that. I'll have a go tomorrow.Nick M;1603670 said:If you do in fact smell fuel, crank the ignition and hold the pedal to the floor. Make sure the battery is fully charged. Hold it like that for 10 seconds or so then let the starter cool for a minute or so and do it one more time.
Can you point out those pins on this linked diagram? http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=IG&P=4...check your volts to your ignition pin and bat pin on the ecu...
