No spark, no start need advise
RTtim
90
lake isabella
Ok thanks. Well I found the problem. Don't laugh at me hahaha. The ignition fuse socket under the dash was loosing contact and when I probed for power I had power but when I would stop it lost connection. All I can say is wow. Well at least I found it. Thanks everyone for the good ideas.
Oct 11, 2005
3,819
20
Thousand Oaks, CA
3p141592654;1696490 said:
Power at IGSW is all you need to turn on the main relay, so even with no power at BATT you should hear the main relay click when you turn the key. If no click, then measure IGSW at the ecu, it should have 12V with the ignition turned on.
:icon_bigg
