Okay guys, i've been out for a loooong while. Been doing a slow rebuild over the past year. anyway to the point. finally got a "stable" tune on the engine and drove her for the first "extended" trip. (maybe 10 miles).
and what I noticed is it won't boost. I'm not trying to floor it, still babying her for a couple more miles, but I'd like to work out as many bugs as possible. So my problem...
Symptom-
Accelerating up to 3500-4000 Rpms, and no boost is seen on either the profec B spec II, or my boost gauge (after market boost gauge) I don't hear my HKS BOV either. It really feels like an NA I don't even hear back spool or nothing.
Car setup- (relevant to turbo)
Turbo - SUPER 70 60.5mm • A/R RATIO .70 • TURBINE HOUSING A/R .84 • COMPRESSOR HOUSING .70 • T4 FLANGE
Fleabay t4 manifold
HK$ waste gate
HKS SSQV BOV
Fleabay intercooler
MAFT PRO - running Speed density no boost control capability
Greddy profec B SPec II boost controller.
Ditched the EGR system, and the PPS.
Running a vacuum manifold witch is ::OLD SETUP::T'd into the Break booster hose.::NEW SETUP:: booster now feeds like stock and the vacuum manifold now feeds off the front side of the manifold on its own port, and that manifold feeds the boost controller/gauges etc.
no stock O2 sensor- running the system in Open loop to allow tuning of MAFT pro.
Diagnostics-
AFRs are a steady 12-14 through out the RPM band.
Fuel Pressure is static 32 PSI
No vaccum leaks.
The car does NOT stumble or stutter during acceleration like it would with boost/vacuum leak.
Drives/idles great minus a slight flucuation during idle (it'll sit at 1000 rpms slowly climb to 1500 then hang there for a second and drop back to 1000 total time for a cycle is about 45 seconds)
Only codes are a 24/32 due to the MAFT pro (i haven't put the resistors in to get rid of them, but this is a issue w/ the MAFT pro)
So any input on where the issues could be at. I've tried messing w/ the Profec B spec II, but I'm not seeing ANY changes at all. I double checked plumbing/connections and all are good. So any thoughts are appreciated.
Symptom-
Fleabay t4 manifold
HK$ waste gate
HKS SSQV BOV
Fleabay intercooler
Diagnostics-
No vaccum leaks.
