newbie tuning help!!!!
boosted2085
I was spoolin :(
Mar 1, 2009
218
houston,tx
i just installed maft pro in speed density mode..i got it used so i reset the setting as close as i could to stock...im new to tuning,im wanting to hit 320-350hp..if some one can send me what theyre setup is on maft pro(speed dens)itll get me in the right direction quicker..thanks...
look at my signature to see my mods to see what kind of set up i can do
shaeff
Kurt is FTMFW x2!!!!
11
Around
NEVER use someone else's tune. Even if two motors are built identically, the tunes will not be the same. What works for someone else, could potentially burn up your motor.
dumbo
1,911
Albera, Too Far North
to reset the maft pro hold the two right keys before you turn the ignition to on. And continue to hold. It will completely reset the unit.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
search in the piggyback section and you will find tons of info on setting up the maftpro. once you get your base tune in, you can start messing with the fuel if you feel comfortable. i recommend a laptop to take logs from the maftpro
boosted2085
I was spoolin :(
Mar 1, 2009
218
houston,tx
well i reset the mp...so im at base settings..but now im getting a weird idle..when i rev it it hesistates..right now im at 40 on the regualtor with vac on so im rich..the hose that went originally to the intake hose from the iac valve is off since i just have filter on the turbo ,when i put my finger in it the motor dies.any ideas guys?
boosted2085
I was spoolin :(
Mar 1, 2009
218
houston,tx
well now i got the car running decent,but the only problem now is when i put in drive the car bogs in the low rpms...i was getting cel51 but even after i got rid of the code it still bogs,ive changed the tps enrichment,decay, even afterstart
