New winshield washer squirters FTW
Jeff Lange
Administrator
4,919
5
Sunnyvale, CA
jefflange.ca
I was just talking about above the hood, yes, the hose is routed differently, and it's a tight fit, but you can make it fit without dremeling it, you just have to position it just right as you are popping it in.
Jeff
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
Jeff
and put the hose on BEFORE you pop it into place.
Ckanderson
2,644
The beach
suprageezer said:
I just received my Camry Squirters, hatch seal, taillight seals, and rear deck lid bumpers from Champion Toyota. A big Thank YOU to Patrick for his help.
:nono:
ask for Jeff at Champion........
Oct 11, 2005
3,819
20
Thousand Oaks, CA
Ahh yes the old nozzle mod! By the way, before I experimented with the Camry nozzles, I used some Volvo V70 ones that definitely did not fit as well, but with some filing on the nozzle clips they did work. They also sprayed with a little wider patch than the Camry ones.
It is possible that the Volvo ones might fit the older hood better. Won't know until someone tries. I'm not sure what I did with them, but if someone wants to try the V70 nozzles I can look for them in the garage. Let me know.
Oct 11, 2005
3,819
20
Thousand Oaks, CA
I had this problem a while back. Was due to slime growing in the reservoir and plugging the outlet filter screen. You need to pull the thing out and power wash it. Also, pull out the pumps and clean the filter screens.
RazoE said:
my front squirters don't work, but the rear one does...
don't know why either, the lines look fine, and the voltmeter shows a tiny dip when the button is pressed, so there's power...
also the reservoir smells like rotten eggs, what do you guys think it is..?
Oct 11, 2005
3,819
20
Thousand Oaks, CA
The Camry nozzle has a smaller footprint than the original. If your hood is faded fresh paint will be exposed around the new nozzle.
Poodles said:
Anyone got pics of the upgrade washer nozzle next to an 89+ nozzle? As many of you know the 89+ nozzle are more streamlined and look better (at least IMHO)
ms07s
TORGUE!
Sep 29, 2007
1,083
Memphis,Tn
Jeff Lange said:
That is quite possibly the worst comparison pic I've ever seen, lol. They are taken from different angles! LOL.
Agreed... The top of one and the front of the other...you fail Suprageezer....
RazoE said:
I have a set on the way, but I just remembered my CF hood isnt going to have the squirter holes..
ill probably just sell them once they arrive...
stout hood?
I had the idea of putting sprayers in the two backwards facing vents to hide em...
ms07s
TORGUE!
Sep 29, 2007
1,083
Memphis,Tn
Poodles said:
stout hood?
Good idea, that would probably work. I wonder if anyone has mounted them under the hood at the edge like some of the newer cars to hide them.
