New time 11.81 @ 117 CT26 powered 7M NEW RECORD!!!
Devin LeBlanc
1,830
Las Vegas NV.
Got the bottom end all assembled tonight. Got to scrape the coating off the 3 layers of the head gasket and re seal it with copper spray tomorrow. Got everything else to throw it back in the car tomorrow night! Everything going as planned!
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
Copper Spray!!!!!!!!!!!!! Mhhhh i dont know about that one. I used to be a firm believer of the damn thing till i saw that all the copper spray hardens and flakes end up in the oil pump. Since then i have been using the Blue or Red Brake QUiet with good results on a MHG that i reused 3-4 times. Good luck Devin
Devin LeBlanc
1,830
Las Vegas NV.
I think I can finally say it. Fastest and quickest 1/4 mile CT26 powered 7M MK3. Did 11.5 @ 120.5 on 19 PSI boost only, full weight other than the spare tire removed.
supranasty
Yo Daddy
Apr 12, 2005
374
jamaica ny
Devin LeBlanc;1769531 said:
I think I can finally say it. Fastest and quickest 1/4 mile CT26 powered 7M hoeMK3. Did 11.5 @ 120.5 on 19 PSI boost only, full weight other than the spare tire removed.
Congrats Devin. This is Hot...
te72
Classifieds Moderator
6,611
7
WHYoming
Fair's fair as far as I'm concerned, if you're trying to hold a particular record for a certain setup, might as well be on the same terms, right?
TheNewRed
572
WA
te72;1769607 said:
You know Rich isn't going to let this challenge go unanswered... :D
Neither will I... good luck over the winter Devin, you will need it by the time spring rolls around.
