New stock internal dyno record?
X-man
member
Dec 5, 2005
309
Pulaski,Va
4000 miles on the engine.
Sean
sethron71;1021399 said:
Very Nice Sir!
Shows what a proper tune allows these cars to do!
How many miles on the motor?
I know I have seen a picture of the engine bay but a new picture would be nice!
Thanks,
Seth
frontierguy25
968
TX
Congrats! Is that a rebuilt stock bottom end then? Did you use NA or GTE pistons.. I'm about to do a rebuild myself again...
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
Awesome numbers....I wonder how long the engine will hold up.
I noticed the gap on your dyno sheet...did your tires slip or clutch slip?
That is usually what causes things like that.
Scot
Enough is Never Enough
Jan 9, 2008
185
Houston, TX
Way to go! Now the devil in the details...
1. What kind of injectors? Modded fuel rail? Fule Pump? What other mods for fuel?
2. Turbo specs.... inlet/ outlet, what part number, etc.
3. AEM map info.... what difficulties did you have in tuning with the AEM?
4. Clutch?
5. How is the drivablitly?
X-man
member
Dec 5, 2005
309
Pulaski,Va
joliroger4;1021496 said:
Congrats Sean! How do you like the AEM? Whats the ignition setup? Did you move to sequential injection?
The AEM is great once you get a handle on everything that it is capable of doing( I'll let you know when I get a handle on everything it will do!). I run a stock CPS, 3 channel ignitor off of a 95 3000 GT, HKS DLI, stock coils with NGK wires and plugs. Plugs are no#7's gapped at .028"
I run sequential injection with injector phasing and ignition phasing for a MKIV TT.
Car runs better than stock.
X-man
member
Dec 5, 2005
309
Pulaski,Va
4. Clutch?
1. 1000 cc PTE injectors, stock modded fuel rail with dual feeds, A1000 and a Kirban 1000 hp regulator.
2. Journal bearing GT4202( 74.3 mm inducer with a S trim exhaust wheel) with a 1.01 T4 housing.
3. The biggest problem with the AEM was me. The unit can be overwhelming with all it gives you the ability to do.
4. Driveability is better than stock.
8,898
Yeah, that is an impressive peak number. Quite a bit of lag there for me, but that has to hit like a sledge hammer when it does.
Nice work.
