New power!!!! 404HP 405ft lbs @ the wheels CT26 on 17.5lbs
te72
Classifieds Moderator
6,611
7
WHYoming
Nick M;1767792 said:
You will go well over 400rwhp with the added comprssion.
Lower temperature alone should be enough to break the 400whp barrier...
Curious question, is a 10.99 possible without sacrificing too much comfort? I.e., stripping interior, sound deadening, etc... if you were to replace things like your brakes, suspension, driveshaft, flywheel, etc, with lighter components? I wonder.
Devin LeBlanc
1,830
Las Vegas NV.
Well seeing the flywheel (flexplate) weighs like 3 lbs and I have a one peice driveshaft already probably not. However if I can get a good 60ft and trap 120mph the car should go 10.99!
I'm shooting for 10's weather I have to gut it to bare sheet metal
---------- Post added at 11:59 AM ---------- Previous post was at 11:56 AM ----------
The way I yielded the higher compression is by going to the thinest head gasket available 1.2 compressed and removing as much material off the head and block possible without making it an interference motor. It has a 12 thou positive deck height and just enough piston to valve clearance to get by. The car is making some breathless now!
te72
6,611
7
WHYoming
Nick M;1767863 said:
That is purely subjective.
True. My definition is "could someone who's old enough to appreciate the comfort enough to NEED it, use the car as a daily driver?" If the car is completely gutted, hard riding, noisy, and hot, it's probably fine for a younger driver, but once you get older, you start to appreciate how comfortable a Supra is when left alone. :)
Nice numbers Devin, knew you'd clear 400 pretty easy. You still haven't done cams or any head work, have you?
8,898
That is what I was getting at. I drove a 5.0 Mustang for a while. And while it was a 1990 GT, there wasn't anything Grand about it.
te72
6,611
7
WHYoming
Devin LeBlanc;1768516 said:
Stock head and cams, however the cams have been degree'd to help with top end power.
Any plans for head work? I know Tyler ran a 10.67 with the R154 and stock head, definitely more power to be had for him. If I remember correctly you have a modified stock exhaust manifold with external wastegate? Any reason you haven't made a tubular manifold yet, other than time?
Haha, good point sir, good point. My 2001 SS wasn't exactly what I'd call "super sporty" either. :p
Devin LeBlanc
1,830
Las Vegas NV.
Yes its a stock manifold with a external wastegate. I personally see no reason to go to a tubular manifold on a stock turbo as I don't think it would help at all.
Stock head and cams for now as they are working fine. But if need be I will start doing head work.
FullNelson
574
Coastal Georgia
Any pictures of the external wastegate setup? I wouldnt have thought you could make the manifold an external wastegate without having boost creep issues.
Devin LeBlanc
1,830
Las Vegas NV.
Did a compression check tonight to see how the motor is after the rings seated.
Cyl 1: 186
Cyl 2: 185
Cyl 3: 185
Cyl 4: 182
Cyl 5: 185
Cyl 6: 185
Thats pretty good for me lol
te72
6,611
7
WHYoming
Devin LeBlanc;1769190 said:
How many dollars per HP are you willing to spend? That's why I see no point to go with a FFIM and Tubular exhaust manifold.
Was it your brother that was the welder for this car? If it's something that can be done for a reasonable price, why not?
