So hear me out on this one:
Being that the stock lines have been proven to support 500 hp, I am planning on going with some slight modifications to the stock lines to run a dual-feed fuel rail on my NA-T 2jz. If one line can support 500+, then it only makes sense that 2 could support 1000.
All of the three fuel hardlines (charcoal canister return, fuel feed, and fuel return) are the exact same diameter. Here is how im planning on doing it:
STOCK FUEL FEED LINE: powered by one Walboro with an inline aeromotive fuel filter in place of the stock filter. This will be attached to an SS braided via compression fitting. The braided line will run to one side of the fuel rail.
STOCK FUEL RETURN LINE: will be modified to be powered with a secondary, identical walboro which will run from tank-> SS flex line -> filter -> hardline -> SS line to other side of fuel rail
STOCK CHARCOAL CANISTER LINE: will serve as the return line to the tank. There are a couple of difficulties to overcome. For one, the line doesnt go down to the bottom of the tank. I think this could cause a lot of foaming. A hardline will have to be added so that the fuel is ejected near the bottom of the tank.
Also, it gets very restrictive near the tank after the flexline that connects to the hardline that runs the length of the car. I will probably stick in a thicker hardline at the tank for the return.
So this is what it will boil down to:
With the engine not running, the return line should be able to send all of the fuel back to the tank without causing a spike in the pressure. This will be evident in how low I will be able to drop the pressure on the AFPR.
I havent been able to find anybody who had done the same thing, so I was looking for some inputs to see if anybody was running a stock fuel return line with dual walboros.
