I have a straight bulkhead with a 90 hose end. Im not looking forward to it not fitting.... Did you try to massage the trunk?
I am using a sump. I plan on blocking off the lines going in the tank.bigaaron said:What do you guys do for the fuel pickup in the tank when using an external pump?
figgie said:Sumping a la Duane.
Only way to keep the pump happy. Also we are lucky in that regards since the tank is mild steel.
joliroger4 said:There is no chance in hell, the gas tank wont even come close. I tapped the bottom of the trunk floor with a hammer a few times and I could tell it wasn't going to budge plus I didn't want to damage the sheet metal, so I just bought the right fittings before I did any damage. Do yourself and car a favor and get the right fitting and hose end.
bigaaron said:The only problem I have with that is I would never have critical parts like fuel fittings and a filter hanging that low off the back of the car.
