New CT26 dyno 573lbs of torque
7M4EVR
695
fah, fah away
^+1 I have Albert's 60-1 and I would like to know what else this guy did to get those numbers. I'm still finishing my build but I wasn't expecting to be close to these numbers at all when done.
Albert
May 13, 2009
1,710
Tempe, AZ
silverhornet;1913600 said:
Any forged internals? sorry for lack of knowledge, whats e85? You use a mhg and stud and nut? or simply as you said above?
reliable?
Alex
yes he had high compression internals. E85 is a type if fuel
silverhornet
28
Wales, Cardiff
I read the thread again, e85 is at 91 octain? Thats crap our lowwest pump petrol here is 95 octain. Highest pump is 99.
I ask so many questions for myself and others who want to do this upgrade. We all start somewhere. Either way most dyno's lye, so you could even take off 20bhp and lbft and still a epic figure.
two-step-n
163
East Mesa
Alberts 60-1's are awesome I beat the shit out of the turbo just make sure your not running the stock elbow and shit small air fliter good luck with your build
flyjum
75
Mesa AZ
silverhornet;1913769 said:
In the uk....
I am not sure this type of setup can be done on sub 100 octane fuel
High boost on a small exhaust turbine + high compression = bad with low octane
Not sure what the exhaust back pressure was when running 25psi~ on this little of turbo but it had to be pretty insane
Suprapowaz!(2)
2,870
San Antonio, Tx.
Pyro15D;1915869 said:
This thread makes me really excited to try out the 60-1 that Albert is building for me.
High compression pistons, 31+psi, E85, stand alone, and lots of timing will get you close to what he made. Let us know how you do.
Pyro15D
kind of a lucky dude
Aug 24, 2008
646
Whidbey Island, Washington
Well, I have standalone, 3 inch exhaust and 560cc injectors so far. I plan on porting the head, 264 cams, and running BBC inner valve springs as well as the usual mhg and arp stuff. I know I won't make that kind of power, but 400 to the wheels would be nice...for now.
IndigoMKII
2,181
Madison, Virginia
Holy shit, 31+ psi from a 60-1 ct26? I'm not sure about the compressor map but that sounds WAY out of the turbine wheels range..
From my understanding, my HX35 is at it's limit near 36 PSI, and my turbine wheel is much bigger than the ct26 wheel.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
Albert;1857741 said:
He isn't going to even mess with it
I told him I need the turbo back soon.
He is putting on the bigger t4 based turbo that flows 77lbs/min. Tubular manifold, external 44mm wastegate, ffim, 1zz coils, 264 cams, spring&retainers etc etc.
Gonna shoot for 600-700. He just needs bigger injectors and a better fuel pump
say good buy to all that tourq
