Ok not to bring this thing back from the dead or anything lol.
So here is all the work I have had done on the motor so far, the good, the bad, and the ugly.
1st Machine shop.
(Asked them to do the following)
1. break glaze on the cylinders
2. deck the block
3. install freeze plugs
The incorrectly decked the block, because they didn't load the block with the mains when they decked. So when I would assembly the motor, it would take it out of line. They also nicked 3 out of the 6 cylinders deep enough to need larger pistons.
2nd Machine shop
(what I asked them to do)
1. Redeck the block with load on the block from the mains
2. Bore out the cylinders to .020 over to get into good material for the rings.
3. Aline hone the main journals being that I was using ARP hardware.
4. Spin .010 of the crank to run a over sized bearing.
After all this they also informed me that the wrist pins for the connecting rods needed to be heat pressed in. Another $80.
So after assembling the motor I turned the entire rotating assembly over 1 time in the clock-wise position. Later, just to make sure I took the final clearences using plasti-gauge, while taking it apart I noticed a unusually early mirroring of the bearings. So I took it to a close friend who was able to mic everything out.
We found they only washed the crank, used standard size bearings, tapered the aline hone on the first two main caps.
3rd machine shop
1. Measure everything out.
2. Notify me of anything they would need to do to assemble.
The very next day they called me back, told me I would need to order a new set of standard size bearings, and bring them in, they would go from there. SO a week later they came in and they let me know it would need to honed a bit because the piston-wall clearance on the first, second, and third pistons where just over 500 thousandth. The final 3 where all less then that. So rod knock would have soon followed after the start up. They also were able to slightly polish the crank, and use the standard size bearings. They also threw in a free bottom end engine assembly
that saved me a bit.
So I now have the assembled bottom end of the motor waiting to have everything else put on it. Ill be taking plenty of pictures of putting the head on and everything else. A lot of that will probably happen tonight, but if not there's always tomorrow.
