CRE;1069591 said:'88 GTE OX is labeled as being white in the '88 TEWD. You should only see the AFRs hit the 20's when you're coasting in gear... then the ECU cuts the injectors.
HommerSimpson;1069625 said:100% positive no IC leaks ? blown coupler ?
CRE;1069618 said:For some reason i would think it would be more likely that you would have killed the LC-1's output then to kill the ECU's sensor ground by feeding it a 0 to 1v signal... Test the LC-1's output and test E2 against +B and then against VC. Against +B you should see >11v, against VC you should see ~4.8v. The narrowband output from the LC-1 should move around between 0v and 1v, in the open air it'll be closer to .1v.
Ground the incoming E2 line to the chasis? Errr.... only if I were stuck in the desert. I don't see why it wouldn't get you home... but personally I'd find another way until I knew exactly what you f#$ked up. I wouldn't boost or anything if did try it though. There is liable to be a voltage offset so sensor readings could be skewed a fair amount.
JJ's probably the one you should ask about this.
Did you have anything patched into the O2 wire? Just making sure you weren't dumping the power from the heater circuit into it or something.
IwantMKIII;1069634 said:Im officially the dummy of the night.......popped a pipe clear off. Didn't notice it b/c it appeared okay resting up against the coupler
