Need some quick help with wiring and more(time sensitive)
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
It was little difficult reading the rest of this thread while shaking my head but I'll clear a few things up. First, putting a NB signal into ground won't cause damage because lambda signals are low voltage/high impedance. Second, in spite of what my own TEWD shows the harness side O2 wire on my 87T is brown, not white. Third, I was advising how to sort the wiring out. At no time did I think the OP's problem was related to it. Which brings us to....
I've said this so many times I've lost count but I'll do it again: In a properly operating TCCS it's not possible for a bad O2 signal can cause driveability problems. You can open it, short it to ground, make it full rich or lean, whatever. It *will not* make the engine sputter, hesitate, bog, idle wrong, or do anything else that'll be noticeable from a driveability standpoint. Anyone who thinks it will doesn't understand how EFI systems work in general and this one in particular.
If you have driveability problems you're wasting time by messing with the O2 sensor. Period. A faulty lambda input will only effect emissions and fuel economy. Now before I hear from people who solved driveability problems by replacing the sensor, save it. All you did was resolve a symptom from a different underlying issue, one that's probably still there.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
I was answer what he was asking to the best of my ability... never said I thought the O2 was the issue. Ask the right question or deal with the wrong answer. ;)
I know the TEWD isn't always right.... hence the diagram as backup. ;)
Yeah, it'll just go to the default fueling maps, adjusted to meet whatever other criteria are met... got it. There may also be a hit in efficiency... gah...
And I did mention the minuscule signal from the wideband probably not being enough to do a thing. Gimme a break.
