need quick help.. int lights & door switches
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
hey ya'll
interior lights are gone, not sure why... does anyone know which fuse it is? if it is a fuse
what are common failures of complete interior lights?
door open switches, one has failed somewhere, even with all doors closed the dash still says one is open, i'm gonna pull out the front door switches and check them but other than that not really sure what i need to look for
thanks for any help :)
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Which interior lights? If you're referring to the Dome lights check the dome fuse and the ground in the dome light housing (common failure point).
jdub
Feb 10, 2006
10,730
Valley of the Sun
Check your Dome Fuse...it's in the fuse block in the engine bay next to the EFI fuse.
CRE
Oct 24, 2005
3,485
Denver, CO
Checked the dimmer? A dead dimmer is a common point of failure for guage lighting... but I don't think the window switches are on that circuit.
If the dimmer checks out fine:
1) check your ground points
2) Test for continuity of the white w/ black stripe wire going into the dimmer with the chassis
3) Test for +12v on the solid green wire feeding the dimmer, in all three switch positions. Off = 0v, marker = +12v and Full on (headlights) = +12v. If any of these returns something other than listed either the light switch has a bad contact of there's a short in the positive side of the wiring.
suprra_girl
7M POWAH! ;)
www.supra.co.nz
digital dash here :p
guages and glovebox etc work just not main lights
window switches are fine :p its the door switches for when the door opens and closes that has failed also
thanks for the tips :)
how would i check the dimmer?
the dash still dims and lightens
CRE
Oct 24, 2005
3,485
Denver, CO
It's not the dimmer then, so forget I suggested it...
So the marker lights in the end of the door's interior and the dome aren't lighting when the door is opened that's the problem?
jdub
Feb 10, 2006
10,730
Valley of the Sun
The reason I ask, the rest of the interior lights are routed through the integration relay #1 (located on junction box #1 - lord only know where it is on your car). The sun visor mirror light and boot light are the only exceptions. I'm suspecting a bad integration relay or the ground it goes to...one is the drivers side switch and the other is the junction box #1 set bolt.
suprra_girl
7M POWAH! ;)
www.supra.co.nz
our mirrors don't have lights... just mirrors hehe
boot light never worked for some reason, couldn't figure it out, bulb was good but just light doesn't go
at that stage dome/door lights worked
so that bolt in the kickpanel that bolts a fuse type thing on to the bottom of the fusebox is the ground?
jdub
Feb 10, 2006
10,730
Valley of the Sun
From what I can tell on the USDM wiring diagram...yes. The problem is your car is backwards ;) LOL!
You'll need to take a look at the the diagram for your car...I'm thinking it's a ground.
suprra_girl
7M POWAH! ;)
www.supra.co.nz
k i'll check that ground down there... it shows on the usdm tewd that the intergration relay is on the back? of the center fuse junction? how on earth do i get to it?
the uk tewd is very similar to jdm so i generally work off that :)
thanks for the help guys :D
Kai
That Limey Bastard
you have a UK TEWD? Oooh. Got it in PDF?
As for how to get to the Integration relay - erm, i have no clue - its one of those things where you're going to have to strip half the dash off to get to it, and maintain a high level of swearyness :D
