Alright well I got the Supra runnin. No leaks so far. I am having some trouble though. At first I had the distributor in wrong but I moved it over a tooth and I checked the timing with my light. Seems to be sitting at about 20-25 degrees before TDC. Idles about like it used to before I ever took it apart though. Missfires at idle and missfires a little bit when reving it up. Sounds good though.:biglaugh: Anyways, after it get's warmed up for a minute it it doesn't wanna idle. The idle get's unstable and it tries to stall itself out unless you give it gas. It had a code for a bad TPS before I took it all apart. I'm thinking the TPS needs to be either recalibrated or replaced. Is there a walkthrough for dummies on recalibrating them? If anyone could help me there that would be super.
I also broke a vacuum hose connector off of something. I noticed I had a vacuum line disconnected under the intake manifold above that vacuum cylinder thing and while I was rummaging around under it trying to figure out where it connected, the hose just fell off in my hand with the connector still plugged into it. I took a pic of it.
If anyone knows where this goes PLEASE help a brother out. Also would this affect idle or cause a missfire at idle? Anyway, here are some more pics of the mostly completed BHG job for those who wanted to see.
