need help with how to wire Apexi SAFC II on 1J
juan jz
197
Anaheim
Need help wiring up the SAFC-II on my 1JZ if someone can point me in the right direction of where to find the diagram and instructions, thanks
Datsrboi
Loud pipes Save Lives
Jul 31, 2007
797
Haltom Texas
Question... On the pressure signal wire I notice after searching there were two arguments on which wires which from the safc2 to use. What was the input(from the harness) and what was the output(To the ecu) wires used? I used a DIY diagram from this forum in the DIY section and it said white and yellow wire. Yet on the forum somewhere it was yellow and something else... Can someone chime in?
juan jz
197
Anaheim
okay thanks for the diagrams but now im trying to figure out what each wire is i keep looking at the apexi-usa website but what is each wire,
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
this is what i used:
RED - Ignition Power
GREEN - RPM signal
BROWN - Ground Wire closer to ECU
BLACK - Ground Wire farther from ECU than brown wire
PURPLE - Knock Sensor
GREY- Throttle position sensor
YELLOW - Air Flow Signal wire going to ECU
WHITE - Air Flow Signal from AFM/Pressure Sensor
BLUE - Optional for Reading Oxygen Sensor Voltage
