hi
my english is not very good but i'll try my best to explain my problem clearly as possible
I just finish my 7mge swap in my 4runner(from a cressida 90) and it was running fine for few days but last night a took the truck for a small ride (first time on the highway)
I was going 70km/h at 4000rpm and the engine start to miss very bad .......i was not able to drive it so I let it cool down .....the temp drop to 180 degree and I tryed to start it again ..everything look fine at idle speed but as soon as I drop the clutch on first gear it miss again and stall
I dont have the speed sensor plugged into the ECU
I don't have check engine light on but when I jump the terminals I have the code 14 ... so I check my ignition coil resistance
I have 10.68 ohm K between the positive terminal and the high-tension terminal.....that's perfect
and I have nothing between the positive and negative terminal... should have 0.24-0.30......
I have 6 function to mesure the ohm on my multimeter : 200 2k 20k 200k 2m 20m and any of them give me resistance
Do I have to buy an other coil ????
i have change the gaz filter rotor cap rotor wire and spark plug ....I carefuly gap my spark plug at 0.028
