Sawbladz said:I would personally be very interested in the pricing that would be available for these driveshafts you plan to make. Are you able to estimate the cost now or will that only be available after you complete a test piece of each?
I fail to see how by using a two-piece shaft that you eliminate the possibility of your vehicle pole vaulting. If the center u-joint breaks leaving the back of the rear shaft still connected to the differential and the rest of the rear shaft dragging on the ground how is it not going to pole vualt if it catches a rut in the road. This is what driveshaft safety loops are designed to prevent.jdub said:AF1JZ nailed it in post #7 with IJ's comments. The downside to the stock 2 piece is the rubber material in the aft shaft. In a Supra, the 2 piece (assuming it's well balanced) produces lower vibration due to the harmonics involved. Plus, (like figgie alluded to) if you bust a one piece, you've just entered your Supra in a pole vault event![]()
shaftmasters said:I fail to see how by using a two-piece shaft that you eliminate the possibility of your vehicle pole vaulting. If the center u-joint breaks leaving the back of the rear shaft still connected to the differential and the rest of the rear shaft dragging on the ground how is it not going to pole vualt if it catches a rut in the road. This is what driveshaft safety loops are designed to prevent.
You wont need it...Sawbladz said:* adds driveshaft safety loop to list of things to do *
Reign_Maker said:You wont need it...![]()
Pole vaulting a car? Myth Busters proved it cant be done, lol... That episode was hilarious... It royally effed up that car, but it didnt pole vault it...
Reign_Maker said:It was a joke... I was sayin he wont have the powah to worry, lol... *BAH! you kids!*
Hi jdub,jdub said:Well, I figure a high jump is better than a pole vault...since a 1 piece is twice the un-jointed length of the stocker. Not that it's really going to matter if the driveshaft drops and catches the ground anyway...it was just a way to point out it's very, very bad. If you're not using a safety loop, it's your problem.
What I was *most* concerned with is driveshaft critical speed per what was in post #7 (IJ's comments). If you don't want to make a 2 piece shaft, that's fine. You asked, so I put in my 2 cents![]()
Thanks it is good to know that they also make them in 1350 series along with the 1310 series that we already have in stock. The transmission yoke for us is not the hard part. It is the hanger bearing stub. As of now we don't know of a source other than a Toyota dealer to order a stub which is only available as part of a complete shaft. We would have to order a complete shaft in order to just retreive the stub off of it.IJ. said:Spicer make a 1350 slip yoke to suit the 340/154 that makes the front easy.
:word8kn: :withstupi :werd:Tun_x said:I just wanted to chime in and say thanks for taking the time to find whats needed and wanted in the community ...
Jason
