Alright... An official update:
I've been to frustrated to continually update the thread so here are some of the problems I've been having:
Fuel AN fitting broke in supply, had to remove a bunch of stuff to fix
Fuel leaks
Turbo Oil lines leaking
Turob Oil studs snapped
Coolant leaks (fixed all, but radiator drain plug leaks still)
Messed up some maft pro wiring
Map sensor wire broke
CPS Wires broke
TPS out of tune
CPS bolt snapped (had to retap)
I now have the engine light on (I think it is a knock sensor code, will check later)
My O/D light is blinking, no speedo so I think it is that sensor
My TODO list:
Repair:
coolant leaks
oil change
fix coolant thermostat housing connectors
fix TPS problem
transmission light
speedo
engine light (knock sensor?)
VSV wires shorten
solder:
maft pro connections (two left)
map sensor connection (green wire)
CPS connection (remove connector, direct solder)
Tune:
Fuel pressure
Tune with maft pro
First thing I want to do is fix the coolant connections. 3 connectors broke off so I did some research and found these diagrams to use.
1. Cold Start Injector Plug
2. O2 Sensor Plug
3. Cam Position Sensor Plug
4. ECU Coolant Sensor Plug
5. Radiator Cooling Fan Sensor Switch Plug
6. A/C Coolant Sensor Switch Plug
7. Air Flow Meter Plug
8. Instrument Cluster Coolant Temp Gauge Plug
9. Oil Pressure Plug
10. From headlight relay, it has been Unknown, but I found it, but I don't see where it plugs in.
I'm making this thread so that it is easier to find part numbers and such later on, and as an easy reference for things, that is why I keep including diagrams hosted by me (so they never go away
I also want to take some pictures, so those will be uploaded soon.
I need help tuning, and I need a picture of how the automatic transmission "kickdown" (I don't know the real name, but I know it isn't actually a kickdown cable) mounts.
