i wouldnt go with a 57 trim or a 60 trim for 500hp..i think some guys using gt series turbo..i am guessing the gt67
The way it was explained to me (and this is physics) is that you can push 10psi through a straw really easy with pretty low CFM, but if you get, say, a 2.5" PVC pipe, it takes a lot more air to make 10psi.boosting185 said:more hp=more boost no?
deranged said:The way it was explained to me (and this is physics) is that you can push 10psi through a straw really easy with pretty low CFM, but if you get, say, a 2.5" PVC pipe, it takes a lot more air to make 10psi.
starscream5000 said:
I have access to at least two highly regarded tuning shops within 20 minute drive, and I will be taking it to one of them for that.boosting185 said:these cars arent cheap..it takes time and research and i always stress proper tuning
foreverpsycotic said:did you check for boost leaks yet?
3p141592654 said:Actually, before you do anything further check for ECU codes. Swapping parts with no clue is a good way to waste time and get frustrated.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=FI&P=23
