born2drv said:ok well the ground isn't the problem, is there another reason why i could be getting the oscillating WB reading??...
how do you know the gnd isn't the problem? where is the MAFT pro grounded? where is the WB grounded?
drjonez said:how do you know the gnd isn't the problem? where is the MAFT pro grounded? where is the WB grounded?
turbobob said:get a voltmeter, and measure the voltage between the orange and purple wires. Compare this to the "O2" reading on the Pro. They should agree.
Be sure your tracking features (AFR Tracking and PT Tracking) are disabled (set the TPS thresholds to 4.9)
Verify where your grounds are connected. Make sure the harnesses are plugged into the Pro well (unplug and re-plug them about 10 times to 'break them in')
High idle speed is generally from too much air getting in. Stuck throttle, vaccuum leak, PCV line off, etc.
Bob
Bingo, unless im goofy, you need the ground output from your wideband controller to the maft pro, not the body ground, that could be it. The ground for your wideband gauge should go to controller , not body also.born2drv said:they're both using the same ground on the frame.
I wired my WB according to it's instructions (to a isolated ground on the body). I then tapped the Pro purple wire (pin 2 on the 10 pin harness) to the WB ground wire (about 2 inches from the actual gauge) as stated in the instructions on page 21 ("...connect to the wideband main ground, close to the unit"..tookwik4u89 said:Bingo, unless im goofy, you need the ground output from your wideband controller to the maft pro, not the body ground, that could be it. The ground for your wideband gauge should go to controller , not body also.
You should have 2 wires, a + & - from the gauge to the wideband controller, That minus should NOT contact body ground, same when you wire the maft pro, the two wire should go directly to wideband controller, NOT body ground. The wideband controller and maft pro should only have ground to body for powering up unit, not in gauge circuit. Purple wire = NOT grounded to body. The wire you hooked up to body is powering up unit, you need to tap into gauge wiring, I assume your gauge just plugs into controller, find out which is -, and tap purple in there.chriso said:I wired my WB according to it's instructions (to a isolated ground on the body). I then tapped the Pro purple wire (pin 2 on the 10 pin harness) to the WB ground wire (about 2 inches from the actual gauge) as stated in the instructions on page 21 ("...connect to the wideband main ground, close to the unit"..
Sooooo, are we saying that the WB ground should NOT go to the body at all but only to the purple wire on the Pro.
That reads pretty clear to me....thanks ! I'll go fix that tonight.tookwik4u89 said:You should have 2 wires, a + & - from the gauge to the wideband controller, That minus should NOT contact body ground, same when you wire the maft pro, the two wire should go directly to wideband controller, NOT body ground. The wideband controller and maft pro should only have ground to body for powering up unit, not in gauge circuit. Purple wire = NOT grounded to body.
The AEM UEGO has four wires other than the plug from the O2 sensor.tookwik4u89 said:ALSO, depending what you have, my dynojet had an aux output pos and neg, so I did not tap into gauge wire, I had seperate wires going to maft pro. Plus you have probably + and - in gauge harness for illumination so make sure you get the right one.
Someone else will have to chime in on the LC-1....NickSupra said:I am slightly lost here. The orange wire of the maft goes to the brown on the lc1. The purple wire on the maft goes to the green on the lc1. Neither of these should have a chassis ground. Is this correct? Then the white and blue wires of the lc1 are grounded to the chassis.
Alrighty then....I just unhooked the chassis ground and connected the MAFT Pro purple wire to the AEM Black wire and the WB would not power up. Soooo this will NOT work.born2drv said:no problem, i'd interested in getting confirmation of how the AEM Uego wires get hooked up as well![]()
