My daily 2jz na-t
suprastupid
177
tx
I don't know why some of my pics aren't show in up anymore.. o well, more pics
Messy and loose coilpacks
Used the old plate to keep em from moving.
Plug wires and harness mounted
Sent from my Xoom using Tapatalk
suprastupid
177
tx
Also got my intake and throttle body done. Wiggins style clamp, iscv delete, vacuum actuated throttle plate deleted, and powdercoated. The retard who coated my intake decided to do EVERYTHING, including gasket surfaces.. He then told me it will seal better that way and that's what you get for a cheap price.. yeah wtf, I then went to a machine shop and got the right surface.
After machining
j3r3my
240
mass
why delete the iscv? its looking good by the way i have a new pic of my ge t build to i just have to upload it
suprastupid
177
tx
I got rid of it because Ill be using a stinger to control the engine, I'm not sure if it can be used to control the iscv and really shouldn't matter without it once tuned correctly.
suprastupid
177
tx
uploadfromtaptalk1305078325682.jpggot this far and realized I got the wrong brackets! Its cool I ordered another set and aaron is taking these ones for a pre89 back
suprastupid
177
tx
uploadfromtaptalk1305078538792.jpg tapped and blasted fuel rail
uploadfromtaptalk1305078619816.jpgnot much room hopefully a cast 90 will fit
uploadfromtaptalk1305078701580.jpg I don't think I can run my 3inch wiggins on it though
suprastupid
177
tx
Got my compressor housing done and the wastegate positioned the correct way.
Sent from my Droid using Tapatalk
suprastupid
177
tx
Some recent work.
Sent from my R800x using Tapatalk
suprastupid
177
tx
Guess whats goin on here??
suprastupid
177
tx
Ecu/relay panel...
suprastupid
177
tx
It fit pretty good.. id say theres enough clearance... it goes in fairly easy with the turbo on.. I think aaron from driftmotion uses this downpipe bit modifys the header for the 1j...
