My Car Wont Sart, But If I Push It, it Starts Right Up And Drives Perfectly
It's simple diagnostics not rocket surgery
ie: If there's power to the Starter relay is it getting to the relay out?
This tells you a) the key switch is working and b) the relay is working, if no to either you now know which isn't.
If yes then check the connections at the Starter if the power makes it that far and there's still no start THEN it's the starter....
These cars are a bitch to change out the starter on so you want to be 100% sure it's dead BEFORE you do the job.
8,897
IJ.;1211833 said:
Or buy a $5 test light and start probing the starter circuit while a helper turns the key...... :nono:
For the OP, the big wire is battery power, the small one is ignition, and should not light until said buddy turns the key to the start position.
giterboosted
cure for the common rice
Nov 3, 2007
597
toccoa ga
i had a problem with this for a long time with my starter, it was the contact tabs inside the starter, which is extremely common on our cars and small older toyota trucks with similar starters, they grind down on the copper tabs inside of the starter to a point where the washer cant make good contact, what with the buildup on the washer over time it simply wont connect, instead of spending somewhere around 50-55$ (around where i live estimate) to have it rebuilt, go to a dealership and pay about $8 for a couple of tabs, take the cover off the starter and replace them and clean the washer really well, been workin like a champ for well over a year, hope i was of help if you havent already fixed the problem
8,897
giterboosted;1211972 said:
....it was the contact tabs inside the starter, which is extremely common on our cars and small older toyota trucks with similar starters, they grind down on the copper tabs inside of the starter to a point where the washer cant make good contact....
This is true. I have changed a few Corolla and Camry starters for the same reason.
Scot
Enough is Never Enough
Jan 9, 2008
185
Houston, TX
UpbeatFish;1211644 said:
thank you but i know the battery is fine
im going to check the connections and such
at this point( thanks to your help) i think the starter is junk
ill check it out thank you
Had the exact same problem... I too told myself the battery was good.... It turned out to be a bad battery...
Had the problem again.... I told myself the starter was good.... It turned out to be the starter.....
This problem never gets old.
ForcedTorque
Join the 92 Owners Group
6,099
Have you run the battery down trying? Define no lights. Do you just mean dash lights that come on with the ignition switch? If so, you have done some narrowing down. But test your battery voltage to be sure.
UpbeatFish
Permanently Banned
Oct 4, 2007
159
Fail town
my batt is perfect, i turn the key and its as if the ignition is disconnected or something , theres no light in the dash board theres no clicking there is nothing. i turn it and it doesnt return it back to start, it does nothing
UpbeatFish
Permanently Banned
Oct 4, 2007
159
Fail town
jetjock;1213563 said:
Lmao. Answer these questions:
1) Do the headlights work?
2) Do the brake lights work?
And undo what you did before. Unground the wire you grounded when trying to defeat the alarm...
1) yes
2) yes
3) already did
hehe=]
UpbeatFish
Permanently Banned
Oct 4, 2007
159
Fail town
jetjock;1213569 said:
And nothing lights up on the cluster when you turn the key on? Nothing?
nothing at all
it was working perfectly
but when i turn the switch where the signals are at
they work
UpbeatFish
Permanently Banned
Oct 4, 2007
159
Fail town
jetjock;1213575 said:
What signals? What switch? You mean the turn signals? Do the hazards work?
yes everything works when it comes to lights
the only thing is when i turn the key....nothing =(
ForcedTorque
6,099
Look what I found! There are two different types, and I have never noticed that. The two have similar but different connectors. I've never seen anything about this, so I felt the need to post the picture, and give some info on those connectors.
This is what you are looking for to disable the alarm.
