My 4 Door Supra Build
I was going to post in here but I think you two might want to be left alone...........:naughty:
wesbeech
Beech Performance Motorsports
Feb 26, 2006
1,022
Akron Ohio
Ok well yesterday i ordered new referbushed rear brake calipers to strip and powder coat. This morning i ordered my megan coilovers. And im ditching the w58 for my r154 because i decided when the time comes im gonna swap in a t56 out of a 03 04 cobra. And that way i can make more power in the cressida and not worry.
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
Looking good, more pics of your engine and valve covers:naughty:
And where did you get everthing to build your serial? Seems like its harder to find that stuff than it used to be.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
When i get them welded i will. Where did i get my parts for what?
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
you were building your own serial cable. Seems liks it getting harder to find stuff to build your own these days.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
You can get them at radioshack but i went to a local eletronics store.
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
huh, guess Ill have to look around. I had a hard enough time finding a regular serial cable, radio shack didnt have much
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Ok well Im still waiting on my rear brake calipers to show up my trd radaitor cap, and my coil overs. I just ordered inner and outter tie rods and a silcone coupler for the intake manifold.
Yesterday i got in my polished ss spark plug galley cover.
And last night i did the bbc valve spring swap.
Look at those oversive valves.
All apart.
Stock on the left.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Well i was bored today so i decied to see if my spare tire which is an 18" rim would fit in the factory spot. I could not beleive it it did almost perfect but i thinks its the biggest one you can fit.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Ok well today i made my oil pan so its ready for the welder but prob not for a bit since im still wating on my manifold. The pan will hold about 2 quarts more than stock.
And i tore the top end off of my 89 jdm 7mgte so i can start preping it for the cressida.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Well today i went and picked up my coil overs. They look amazing i just am not sure where the front endlink hooks up at but im assuming the lower controll arm.
And i picked up my RCA's
I got the word my cams and head studs are on the way. My cams are a 274 duration and 226 at .050 which is bigger than the bc stage 2 cams.
