Grimsta;1194900 said:Currenltly Supraless? What happened Steven Colbert?
LOL, the Supra has a new owner. Maybe he'll post some vids soon
hottscennessey;1194763 said:3 deg of base timing, as in with a timing light, by adjusting the CPS??
diabolical1;1195281 said:this is a badass thread. congratulations on your swap. you almost gave the illusion of it being easy.
just to clarify, you mounted this with MA70 mounts and JZA70 brackets? so it's virtually a bolt-in then?
good job!
Adawg;1195291 said:where did u get the rear sump oil pan for 50? you gotta hook me up with that deal.
juhanis;1195391 said:yep. any suggestions with that? i want to run 14psi max, 10 for now. i have 550's, vpc, afpr, safc2, 57trim t04e, big greddy fmic, wideband, progressive methanol control. i just listed those mods so you know what i'm working with.
hottscennessey;1195451 said:I wouldn't recommend skewing the timing using your base timing unless it's a last resort. There are other ways to do it even with a piggyback setup that has no timing control.
I can elaborate on this if you need me to^
What size HG are you running?
On my car, I was running what I considered very aggressive timing, I went to the dyno and made 450whp... I couldn't believe it. I grew a pair and went back two days later, positive that the car was in 100% mechanically and there were no physical restrictions. I added about 2-4* of timing to the ignition, map in select places, and made 677whp at less boost .
What size nozzle are you using with your methanol injection? The reason I ask is because I've heard of people running methanol and losing power vs the same boost level on 110 leaded. They were on the stock ECU, they weren't running any crazy setup that would make me think they were detonating forcing the ECU to pull timing. Methanol will not kill power if tuned correctly..
The previous story, plus my experience tuning methanol, and some of my research done on the Buick Grand National forums all lead me to believe that if you're running enough methanol, there is a chance even the stock ECU may not be able to give you enough timing.
Grimsta;1196897 said:What you need is a more powerful spark
hottscennessey;1196918 said:Ahh, the stock HG.
Honestly, since you're running a 7MGTE ECU I don't think you need to retard your base timing more than a couple degrees.
From what I'm told, using the stock knock sensors with the SAFC is not going to give you a good indication of knock. Are you getting repeatable reading?
hottscennessey;1197071 said:haha very nice, what plugs are you running?
Also, what coils are you running?
Grimsta;1198242 said:You dont gap iridium plugs! You can mess up the electrode like that!
