My 240SX thread
MrVito
67
Augusta, GA
MrVito
67
Augusta, GA
Feb 20, 2011
Was just going through the donor car to pull the boost, water temp and oil pressure gauges out along with the pillar pods when I noticed a manual boost controller stuffed on the side of the drivers seat, and the HKS turbo timer I somehow completely missed before. :)
MrVito
67
Augusta, GA
Feb 25, 2011
Pulled a couple of bits off the motor after dinner today, replaced the plugs while I was at it.
Clutch has seen better days....
Pressure plate is done as well
Flywheel is looking just as bad as the pressure plate
Slight leak on the rear main seal
MrVito
67
Augusta, GA
A few drops made it to the back of the flywheel as well
Plugs show that she was running a little rich, but that's to be expected when the BoV wasn't recirculated
MrVito
67
Augusta, GA
New pump!
Pulley is dirty, rusty, and generally looks like garbage
Woops, forgot to drain the oil before I pulled the motor, now seems like a good enough time
MrVito
67
Augusta, GA
Everything back together on the front
Finally got around to putting the new lines on the turbo as well
Going to try to motivate myself to get more work done while it's so nice out.
MrVito
67
Augusta, GA
21 Apr, 2011
Flywheel is torqued to spec and the pilot bushing is in
Clutch fork, carrier, and release bearing are installed as well
Clutch disc is on
Pressure plate is on
MrVito
67
Augusta, GA
22 April, 2011
Got a couple of pics with the wifes camera. He's going to buff her this weekend. Then she'll come back to the house on one of my days off next week. Still need to get the trans put back on the engine.
MrVito
67
Augusta, GA
Not that you can see it, but the water and oil lines for the turbo are all done up correctly this time
Turbo and manifold back on, lines on and done, just about ready to go into the car, which should be happening next week, FINALLY!
MrVito
67
Augusta, GA
12 May, 2011
Not that you can see it, but the core support is FINALLY welded on, she should be coming home tomorrow afternoon/evening. Oddly enough, this crappy cellphone pic shows the color better than any I've seen so far. They're in the process of doing the final polish right now.
04 June, 2011
Had to pull the front tension rods, tension rod and sway bar mounting brackets off of the donor car, as the silver one doesn't have them. They were filthy with a few sections of the paint chipped through.
Got them cleaned up and they look like this
I've painted them too, they're drying right now, but I'll get pics of them tomorrow, and hopefully mounted on the car as well, after that I need to swap over the Z32 brakes, and then put the engine in.
MrVito
67
Augusta, GA
02 July, 2011
Got some work done today, thanks to HumP for stopping by and providing a different perspective, made a world of difference.
03 July, 2011
Valve cover needed the paint stripped and a hole filled, (engine balancer gouged the front of it during install). After the filler is fully cured, it will get sanded down, then the whole thing will get filler primer to smooth our the scratches on the back of it.
