My 1JZ Swap!
apexi287
401
Knoxville, TN
Well the update now is the motor and everything should be here Friday!:biggrinbo All the seals and lines I have ordered I should have wednesday, so the remainder of the week I'm hoping to complete pull the old harness and all the other odds and ends (intercooler/pipes, throttle cable...) I'll update with more pics when i have more progress.
My main pain right now is getting info through 935 about there y-pipe/down pipe, I dunno if it'll work out. If that falls through is there any other company's that make a y-pipe? I know of places with the down pipe but haven't see any other y-pipes?
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
apexi287
401
Knoxville, TN
Yeah I'd have to agree about the quality they do look well made. I think I may just pick one up off ebay as they are a little cheaper and I'm not get much response from 935.
apexi287
401
Knoxville, TN
Yeah after thinking about, looking it over and talking to the guy I decided to place my order. I should have it in 4 business days:eek3dance.
apexi287
401
Knoxville, TN
Well I got a little more done tonight, everything is basically done that can be done until I get my other parts and the motor.
I first took the rest of the stock IC out which was simple just like everything else just a couple bolts...old IC out...
Old IC:thumbsdow
The next thing i got to was the old throttle cable and I took out the cruise control because I won't be using it:cool:..
Then I unclipped the rest of the wiring harness from under the dash about 5 connections. Pulled it out to reveal a hole that I'll need to cover up as I'm re-routing the 1J wiring through the speedo hole..
And the last thing I had to do is get the old DP off. Climbed into the foxhole and unbolted the two bolts from my testpipe and pulled it out..
More to come guys, I'll check out all the parts I get tomorrow and post them up!
apexi287
401
Knoxville, TN
I got a couple parts in from Driftmotion today everything looks great especially there high pressure lines..
Front Main Seal...Part number 90311-46001
Rear Main Seal...Part number 90311-90006
2JZ Throttle Cable..Part number 78180-1B090
DM 1J Power Steering Hose
DM 1J Hydrofan Pressure Line
