morganson's COP S-Type setup
morganson
274
Columbia, SC
Also, have now setup with dual ignitor and voltage step up. Tested at 18 and 24v. i have not been able to test over 14 due to an unfortunate loss of a FCD by the us postal service and a chewed up 1st gear (currently being fixed)
If anyone would like to let me know how to get past this 14psi mark i can continue on with the mad science.
rpk2012
F' LHD
Apr 4, 2005
169
Lubbock, Tx
Thanks to Morganson, and Nathaninwa for the parts. The harness was superior and looked better than some OE harnesses. The plate looks great, but have not received the coils yet to test fit. Will post results soon!
Enraged
A HG job took HOW long??
24
Victoria, BC, Canada
Wow, can't believe I missed this. I'm currently running IS300 coils with DH61 and AEm v1, they work well but are ugly.
Plates and harnesses still available?
Any info from people running these with a DH61 and AEM?
morganson
274
Columbia, SC
I still make harnesses but im not sure where nathan stands on the plates. Pm us for info
KKZ SupraMan
163
ohio
morganson;2022737 said:
Isnt plug spacing for the 2j and the 7m the same? If so the plate should work on a 2j.
I think you are correct on that but I think that they mount differently but a little modification one should work
empera
Authorized Vendor
Philly.
KKZ, PM me with pics of your set up? I'd like to ask a couple of questions in going with this.
Thanks
newlife
10
ohio
i did this mod and i think my harness is wrong idle is way rough what are the reads i should get if i put i multimeter on the harness
morganson
274
Columbia, SC
On the female plug, with the locking bit facing up, while looking at the back of the plug....
1,6. 2,5
3,4. 12v
morganson
274
Columbia, SC
Hey, so little update now running 16psi no break up.
Lex maf, 550 cc injectors, Dual ignitor or single doesnt matter works both ways.
New double shielded wire from the ecu to the cps, 12v to 19v step up box driving the coils.
Rollus
593
Paris, France
Hey I was thinking the same: using a dc-dc converter as a ignition amplifier.
I'm pretty sure they are better than the 2 wires Nology amps. I'm not sure how they perform compared to DLI from HKS or MSD..
morganson
274
Columbia, SC
Its the same stuff underneath. Trick is msd uses more voltage, 36v i believe. Which is fine for these coils too by the way. Mustang guys have been doing this for years. I am going to test a 24v box soon for fun. But right now the 19v does everything i want.
