^ Uhm...
20-50 would be way too thick, especially for a new motor. Pressure is resistance to flow, you don't want High pressure, just appropriate pressure.
And you should definitely wait more then 1000 miles to break in!!! I'd wait til at least 3k miles, but I still don't think the engine is 100% broken in by then, don't jump the gun on switching to synthetics.
Don't stay at any RPM for too long.
Heres how I plan to break-in:
[Edit]Single weight 30W mineral oil (non detergent) [/End edit.. had the voice of an IJ in my head
Don't use a multi-viscosity, ie 5w30, for break-in]
Start it up, bring to 1500 rpms, pulse the pedal up and down about, probably 1300-1800 rpms, until it warms up (assuming the car runs fine until warmup)
Shut off, change oil, check all fluid levels, make sure theres still no leaks (check on initial crank obviously, and don't forget to pull EFI fuse and crank until you see oil pressure before trying to fire it up)
Then I will essentially drive it normal, not letting it idle real low or ever stay in one spot, give it some pressure (accell and engine braking) but staying below 4k, you don't want to drive it hard, but you do need some pressure (don't drive like a granny) to seat the rings.
Another oil change and check up at 20 miles.
If new hardware, re-torque headbolts / studs after about 5 good heat cycles
Another oil change at 500 miles
Then you're probably good, I'll probably change it again at 2000 though, and then go the 5k miles on it
