1989 Toyota Supra full Drag car - with retaining street legal for now.
Car built by:
Tun_x
SuperRunner
Modifications:
Engine:
2JZ swap
reworked block
modded oil pump
GRP aluminum rods
CP high compression pistons
Titan Mains
ARP main studs
ARP L19 head bolts
Brian Crower 280 high lift cams
Shimless buckets
Trans/Drivetrain:
Monster Performance(by PRTC) Built Powerglide
Monster Performance(by PRTC) converter
Original Phantom(now Biondo) powerglide shifter
ATF trans adapter
Custom Aluminum 3.5" driveline with 1350 joints
driveshaft loop
custom 1350-toyota yoke
Trans shield
Stock LSD 4:30 rear end
Wheels Tires
Weld RT-S 10x15 Rear
Weld RT-S 4x15 Front
M/T 10.50x28 Drag Radials
Turbo/Intake
Comp Turbo CT6-88 Billet BB - (currently upgrading from Comp Turbo 76MM cast)
Monster Performance stainless exhaust manifold
Dual Tial 44 WG
4" downpipe
Monster Performance intake manifold
Accufab throttle body
4" intake to TB
3" intake from turbo to intercooler
large 4" intercooler
custom coupler braces
large breather kit with polished valve covers
Fuel System
Weldon 2032 Fuel pump
-10AN feed
dual -6 feed to rail and center return
1600cc injectors
Aeromotive FPR
Nitrous Express Single wet shot
Electronics
AEM 1900u ECU
AEM Wideband
AEM boost soleniod via AEM
5 bar sensor
M&W ignition system
Chassis
solid aluminum motor mounts
solid aluminum subframe spacers
10.5 chromoly roll cage
Car built by:
Tun_x
SuperRunner
Modifications:
Engine:
2JZ swap
reworked block
modded oil pump
GRP aluminum rods
Titan Mains
ARP main studs
ARP L19 head bolts
Shimless buckets
Trans/Drivetrain:
ATF trans adapter
driveshaft loop
Trans shield
Wheels Tires
Turbo/Intake
Dual Tial 44 WG
4" downpipe
4" intake to TB
Fuel System
-10AN feed
1600cc injectors
Aeromotive FPR
Electronics
AEM 1900u ECU
AEM Wideband
5 bar sensor
M&W ignition system
Chassis
