Scince the old suspension review section got erased scince SM was hacked, and not to many people posted there anyways, I figure we need a new thread or even a sticky on what suspension set ups you guys are running and how you like it. This way it will prevent the almost daily questions on what spring/ strut como to run, and how low each set of springs are. Ill start.
I was using some the old version of the Suspension Technics springs and worn out stock struts. It was very low, I would say about 2" lower and the ride wasnt very good because of the old struts. I did install the ST sway bars kit and it made a huge diference in cornering ability, but the ST swaybars seem to break off the lower mouting tabs on the rear. I had to repair both sides, and I added another gusset to srenghten it.
I will be running some TurboR Bilstiens next but I am wondering how the different lowering springs compare. I heard that the H&R's and Intrex are very low, the Eibachs are progressive springs and unpredictable handling because of that. Also the front is lower giving the car a raked apperance.
